Where forced draft (FD) fans create positive pressure, induced draft (FD) fans create negative pressure, or put simply, suck air through a system. Frequently ID and FD fans work in concert in boiler applications. In such applications, the ID fans must be constructed to handle high temperature gases and high particulate loadings. ID fans are widely used in the food industry to extract cooking odours from the process before passing them through filters an scrubbers prior to extract to the air.
- Stainless Steel
Common fan features
- Shaft sealing from simple PTFE glands through to nitrogen or water-purged carbon ring seals
- Ambient air inlet filters and silencers
