Odour control involves venting large volumes of air from such as food preparation and chemical plants and passing the contaminated air through bio-scrubbers before exhausting it to atmosphere. If there is heavy particulate loading in the airstream, a self-cleaning fan would be recommended. In chemical plant applications, a more corrosive resistant impeller design may be required to ensure long-term durability.
- Carbon Steel
- Stainless Steel
- Coated Carbon Steel
- Hastelloy
- Titanium
Common fan features
- Shaft sealing from simple PTFE glands through to nitrogen or water-purged carbon ring seals.
- Ambient air inlet filters and silencers.
- ATEX in-house testing and certification.
