Oven exhaust or extract fans are necessary to keep any process fumes or smoke from leeching into the wider manufacturing environment. The oven itself will likely be under positive pressure and an exhaust fan, sized to match the combustion air-flow, is required to extract the fumes. The fan however must not be instrumental in reducing the oven temperature and may dictate siting the fan at the cold end of the oven as is done in continuous process ovens. Two small fans may instead be sited at the entrance to and exit from the oven.
- Carbon Steel
- Stainless Steel
- Coated Carbon Steel
- FRP
Common fan features
- Ambient air inlet filters and silencers.
