The choice of fan for process heating applications will depend on whether the air is forced (FD) or pulled (ID). ID fans for process heating will require a high-temperature performance particularly of the bearings to ensure high reliability since the heated air passes through the fan. Smooth airflow for controlled combustion or heating is critical in these applications, as is reliability, mandating careful selection of impeller design, construction materials and special features.
- Carbon Steel
- Stainless Steel
- FRP
Common fan features
- Ambient air inlet filters and silencers.
