Vacuum fans are basically high pressure low volume induced draft fans. A powerful vacuum can be employed to transport materials, for holding work-pieces in place and the cleaning-up the workplace or machines of swarf and waste material. Vacuum fans are also used for stacking and transporting sheet material. Consistent airflow and constant pressure are critical to such applications.
- Carbon Steel
- Stainless Steel
- Coated Carbon steel
Common fan features
- Shaft sealing from simple PTFE glands through to nitrogen or water-purged carbon ring seals
- Ambient air inlet filters and silencers.
